All,
I have just bought a 2007 GS with 59k miles. The ABS unit was rebuilt in February, so I understand.
I have done 55 miles on the bike. Took my wife for a spin and within 2 miles of home, the bike ground to a halt - the front brake was locked solid. The lever too was solid.
I recall this happening to the seller (a friend) just before he took it in for the ABS unit to be rebuilt.
I managed to free the calliper, and my elder son picked my wife up and took her home. On the 2 mile run home, it jammed again - I did not touch the front brake at all. My son brought tools out to me and I pulled the pads out. It is only the left hand calliper that is jamming, the right is free. The left has the ABS ring.
I rode home the half mile carefully and I figured the pistons were probably seized and the brake was dragging and jamming due to heat. WRONG. I managed to get the pistons back in (had to release the bleed nipple on the calliper) and I put the pads back in. As soon as I turned on the ignition and pulled the front brake, I could hear the ABS Servo and run and the left hand front brake jammed solid again.
I've messaged the seller (as I say he is a friend who will be horrified). Is this common, and what is the fix. As I said, the ABS unit was apparently rebuild in February. There are no warning lights on the dash. I don't have a GS-911 reader so am not sure whether there are any fault codes.
Help!
BSR67
Help!
BSR67
