I’ve got a similar lift for my Guzzis.
I use a square 15” timber ‘pad’ to go underneath the sump.
Perhaps even shape it to exactly match the underside?
Here it is, showing the underside. The piece of ply fits snuggly between the lift arms so it doesn’t move around.
I'va always used a scissor jack when servicing my old Electraglide, similar to this ...........
https://www.ebay.co.uk/itm/28362899...nAAN4i5drAAEEW9/sG5WPXo7s=|tkp:Bk9SR7DL7M_aYA
500 Kg capacity, wind it up/down with a ratchet wrench. OK, it can't lift the whole bike skywards, but fine for most DIY tasks. My neighbour borrows it for his old British Classics occasionally.
If you go hydraulic, make sure the lift can be locked mechanically if it is to be left in the raised position for a period. Obvs check there is sufficient clearance too.
The original of these is the J&S Jacks which are designed to lift Harleys and are very heavy duty, but also very difficult to get hold of in the UK.
Below is a pic of my RKS on the J&S that I was lucky enough to acquire from a gentleman of this Parish.
The Halfords looks like a similar version, so if you want to pop round and try your R18 on mine, then just drop me a PM. Your mate Chris (Urban Rider) knows where I live and has my contact details!
ATB
Toddy
ATB
Toddy
Use this on a similar jack for ifting Eldorado 1400, works a treat.
ATB
Toddy
Hey Toddy, I just came across this elderly post of yours. What year is your RKS? (you have the smaller, more tasteful engine bars on yours).
