So, what are these beasties like when you get deeper than the pots... I realised I do that kind of depth without thinking about it... with fuel injection.
So axle-deep to be safe, but take a plug spanner, and make sure you can loosen the exhaust pipe joints )
A wave over the crankcases obviously isnt desirable.
What about water in the front casing ?
As long as it did not go over the plugs I found all else was OK, although I would get some ingress into the gearbox but nothing that needed sorting on a ride, just an oil change when convenient
