Who gives fuck is my response. Goretex gloves and heated grips work for me, I don't really care what anybody else says. Just let them think they are right and move on.........
You are so right. Move on….
maybe
i don't see how with heated grips the water vaporises, surely temperatures need to be higher to turn a liquid into a gas
are water vapour molecules smaller than sweat or is it the heat makes the pores of the gore tex expand
maybe we ought to ask this guy
https://www.gore-tex.com/en_uk/blog/when-is-a-garment-waterproof
Now that you have told me to, I'm staying put.....You are so right. Move on….
I'm sure you do old bean, you're just not letting onOne minute going; the next minute, staying.
I don’t know what the world is coming to.
The Goretex membrane is in most circumstances**
** Like all waterproof fabrics Goretex has a hydrostatic head which effectively how much pressure is needed to start forcing molecules of liquid water through the fabric. I don’t know what the HH is for Goretex but I don’t think it’s very high as water definitely comes through areas that are stretched or flex frequently, eg over knees or elbows.
Goretex and the like isn’t really needed for a static activity like motorcycling, at least not while you are sat still zooming up the motorway. Off roading or when off the bike walking about it does have its benefits.
Have a search for what is the hydrostatic head for gore tex, I found “ As a rule of thumb guide an hydrostatic head of 3000 is decent waterproofing, however if the jacket is used with a rucksack a much higher value will be needed. e.g. Gore-tex which has a minimum rating 20,000 when the jacket is new.” at https://www.outdoorgear.co.uk/hydrostatic-head.asp… Like all waterproof fabrics Goretex has a hydrostatic head which effectively how much pressure is needed to start forcing molecules of liquid water through the fabric. I don’t know what the HH is for Goretex but I don’t think it’s very high as water definitely comes through areas that are stretched or flex frequently, eg over knees or elbows…
There are lots of posts where bods say that using heated hand grips, sends the Gore-Tex into reverse, allowing it to draw water in.
If this is the case, why doesn’t my jacket draw water in when I use my heated liner? Why don’t my trousers draw in water, when I use my heated seat? Is there some fundamental difference between a heated grip and a heated seat, other than one warms a rider’s hands and the other, the rider’s bum?
The reason it happens in motorcycle gloves is because you're in direct contact with the heated grip holding onto it. It causes something called Osmosis which makes water move from a hot side of a lining to the colder side.
It won't happen to everyone, but it's certainly something we see as a retailer every now and then when customers complain that their gloves are "leaking". If you pop your gloves hand into a bucket of water and it doesn't come through, they're not leaking... the problem will be water down the cuff.. or you're using heated grips and it causes the effect to happen.
Unless things have changed when I was at school Osmosis has nothing to do with heat. Osmosis is when a weak solution transfers through a membrane to a more concentrated solution. Hence R O units in hospitals and sailing vessels.
