Pretty much unique in all the world's inline 4-cylinder engines, the R1 has a cross plane crank.
Uneven firing, massive primary vibrations and added weight and complexity.
Who knew?
Don't think so. At first glance, yes, but think again.
A Single Cylinder or parallel twin engine has horrible Primary vibrations coupled with, to a lesser degree, secondary vibrations.
A 180 degree crankshaft parallel twin has no primary vibrations, but a significant rocking couple and secondary vibrations.
A BMW style flat twin has neither primary nor secondary vibrations, but it does have a very significant rocking couple.
On 1200 on engines, BMW fitted a single balance shaft. ( They should have used 2 to remove the rocking couple completely.) Thus, they quartered the amplitude of the vibrations, and multiplied the frequency by four.
A "Flat 4" engine has neither primary or secondary vibrations, and no rocking couple.
A 4 cylinder single plane crankshaft engine has no primary vibrations but secondary vibrations.
A Vertical Twin engine with a 90 degree crank, or a 90 degree Vee twin have no primary vibrations because the 90 degree masses cancel one another out, as do the secondary vibrations. They do, however have a tiny rocking couple.
A 4 cylinder crossplane engine, just like the 90 degree vertical twin engine has neither primary nor secondary vibrations, and the rocking couple is cancelled out as well.
Thus, like the flat 4 engine, it has perfect balance, but uneven firing intervals.
Look at other posts to see why this is advantageous.
