I made my own tools out of thin wall brass tubing as used by model makers, but there are automotive terminal extraction tools readily sold on eBay at reasonable prices, but not sure whether they will fit the BMW terminals which are bespoke BMW.
Eg.
I assume they use a cylinder which has to be pushed in on the side of the wire? Does the right tool have a slot which allows it to go over the wire?
Thats great, is there a specific BMW tool as all the ones I have are just too big!!
try motorworks. I need to re do my horn terminal connection. They sell a complete replacement set of terminals and the plug. I just now need to do the crimping and joining. Not something I am looking forward to..Wiring repair kit horn socket
ELA59999-1
The horn connector on the R1150 is an MQS connector, and are readily available together with their contacts. It’s a connector universally used throughout the automotive industry so not specific to BMW, hence why it’s easy to get.
The main connectors on the R1150 and earlier bikes are the same connectors used on many of the BMW cars of the same period and were manufactured by AMP, later Tyco, specifically and exclusively for BMW use only.
As in assembled? If so, how do I get the wires in? Thanks for the info, been struggling to find out what these connector things are called
