What do you suppose has happened here? Maybe cylinder studs pulled out? It's for sale on Ebay.
Item 364108563640
Sent from my SM-G925F using Tapatalk
Item 364108563640
That's a lot of money for a pile of scrap.
AS THIS IS A USED ITEM IT MAY EXHIBIT MINOR SCRATCHES, BUMPS, DENTS, PAINT DAMAGE OR GENERAL WEAR AND TEAR.
Decent money in the heads and transmission. Shame one of the stubs is ripped off.
look again , the barrel is broken at the bottom , and a crack from the 2 o'clock stud going diagonally upwards .
if in doubt , look at ht wire , plug cap rubber , just above , there seems to be a bit of the barrel.
The block is definitely cracked in the other pics. There isn't going to be much salvageable there. I wonder how the rider faired? He might have gotten away with it if he parted company and ended up in a field. I hope so.
