Well who knew? I’ve never seen these before. Heated elements that fit inside the handlebar tubes. From SWT in Germany.
I saw them originally on a fb group and someone said they work really well. Another advantage is they won’t get damaged in a spill as they’re inside the bars.I wonder how well they will work ? I have always found with the BMW grips on every one I have owned or ridden that the right hand grip is always hotter , assuming because the right grip has the plastic throttle tube which acts as an insulator from heat loss directly into the alloy bars
I’m guessing a hole in the handlebars like the original BMW GS heated grips.Am I being thick but unless using clip on's how would you fit these to say a set of GS handlebars? ie get the wire from inside to outside?
Try SWT Sports and search ‘ heated grips’. There is an English translation button if you don’t speak German.Look interesting ... I have searched for 'em but no luck ... got a link by any chance
The new generation of Oxford heated grips "UK specific marking on the box" get SUPER HOT. Way way hotter than the older style. On par or better than BMW genuine grips.
I have always found with the BMW grips on every one I have owned or ridden that the right hand grip is always hotter........
