I've recently got a 2018 r1200gs.
I'm wanting to learn basic spannering to look after it. To date my spannering has been on push bikes only.
So far I've done the following, lubed the splines at final drive, changed the final drive oil, removed and refitted the silencer, the bash guard, and serviced the brakes.
1. The brakes, is copper lube best for the pins, and the caliper bolts? And should this be smeared on the backs of the pads?
What lube should be used for the rear brake where the slider pins (?) Go into the rubber bits? Apologies for the poor description.
2. What anti-cease grease should be used where heat is a factor e.g. exhaust clamp and brake caliper bolts?
3. Is any old grease good for things like bash guard bolts?
Your wisdom and information is much appreciated.
If there are any other specialist lubes you think I should know about please update me.
I know not to grease the rear wheel bolts.
Cheers Karl.
Cheers Karl.
