Hi all, I am refurbing a pair of R65 ATEs, thoroughly cleaned them and put in new (aftermarket) seals and SS pistons. While the pistons go in smoothy on both inner halves, the pistons will not go into the outer halves. I think the piston crown does manage to go into the seal, but it will not go any further as if the seal is binding on the piston. The seal recesses look ok, nothing to prevent them from seating. I've tried silicon grease and brake fluid, neither does the trick. C-clamp no joy. Anyone had such a problem with a caliper rebuild to get a piston in?
