I'm fairly sure I know the answer to this, but I thought I'd ask in case I'm being dumb as a bag of hammers...
I've an 84ST and the the oil light flickers when the engine is very hot and it's on idle (bout 900 RPM) at traffic lights / junction or the like.
If i raise the revs to 1250, the flicker buggers off and all is well. Drop the revs and the flicker is back instantly.
It only happens if the engine gets really hot due to traffic / stop start driving for 5 or 10 minutes..
Once back on the open road and the engine gets a chance to cool, stopping at a junction does not bring the flickering light back.
The oil pressure switch was replaced recently as the old one was leaking. Unfortunately, I don't have a pressure gauge to have to verify that the pressure is dropping off when hot.
I will say that the problem was way worse on semi synth (put in at last service by reputable mechanic).
It did get much better when I started using 20-50 mineral oil and a Mahle filter.
I have no history on the bike and I reckon it had a harder life before I bought it and the speedo replaced at some point in the past, so no idea on miles.
Should I just park her up and talk nice to herself and the bank about funding a rebuild?
Am I missing something silly?
Opinions / ideas and suggestions gratefully received.
D
D
