On my way back home from a ride yesterday my right hand side valve cover started leaking oil, at a noticeable level it was covering the lower engine case & creating a small puddle sump guard. The LH side also appeared to be leaking, but not as much. And what i can't figure out is the front wheel also looks to have some oil splatter on the right hand side too. No idea if this is spray from the valve cover, or not?!
The front cover of the engine looks clean and dry, and the bottom of each valve cover was wet, so i am assuming they are the issue. I've removed both sides and the gasket looks in good condition, and the spark plus hole is also dry - so this o-ring must be good too. The bolts appeared to be tight/at torque spec, and the covers have not been off in the last few months/2K miles.
- Oil level has always been fine, sitting just below full when at operating temps
- Bike was working fine prior to this and was sat on the Motorway at 4K rpm
- Bike temp not breached 100 degrees, and fan always kicks in when it gets hot
A couple of questions;
- should the valve covers be replaced at a particular interval; mileage / time frame; 2 years / or number of times gasket has been removed to check valves
- is there another issue which could cause oil pressure to build in the covers and to leak - something like a blocked breather, high oil level etc.
