1989 R80 Mono.
According to the Haynes manual, the three main parts of the clutch assembly are marked at their heavy point. I'm expecting the new parts to be marked on their arrival. However, My flywheel does not have any marking that I can find. I guess the paint has worn off over the years. Is it simply a case of the heavy point being between the two timing mark tabs, or is it more complicated and I'll be in for some fun trying to work it out?
Also, a special grease (the name of which escapes me right now) is recommended for use at certain points in reassembly. Is it some sort of dry grease, or can Copper slip be used instead? Buying a whole tube of something I'm only going to be using a few smears of irks a little. I do have a tube of 'Optimoly Paste TA' high temp grease 1100c Any good???
Val
Val
