is there any one around here can recommend a good home visiting type dent repairer man. i am in need of such a person as my vehicle has a dent which needs attention before it goes back to the lease company.
Ta
Ta
Pop into any large franchise car dealer and get the name of their dent man, they all use them, and if he is recommended by a dealer he will be fairly competent.
depends on the type of dent, but you can do it yourself.
hair dryer and pipe freezer spray.
if it's a proper circular dent well away from any crease lines, and the the skin has not been stretched.
firstly warm the centre of the dent with the hair dryer till it really warm 40is degrees same as hot bath. then spray the centre of the dent with the pipe freezer.
it'll shrink and the dent will pop out.....
if your lucky....
if it's on a crease the chances of dentman fixing it are low...
