I nearly bought a bike which was to be supplied with a set. Note the video is filmed on a icerink flat floor, no bits of grit or anything, for sideways movement I expect any small bits of grit or uneveness may mean the movement is less smooth.
You could simply add the special wheels (Rotacaster) to a normal paddock stand and get similar results. Although you may need to adapt the axles/wheel positioning. Would be the same solution for a lot less cost.
