GSA Topbox Hinges
Neil W
Northumberland
Recently acquired 1150GS has a GSA top box fitted and typically the cheap sh*te plastic hinges are cracked , I am not paying BMW prices for replacement Southco parts (same sh*te ) or buying even cheaper quality Chinese rip off rubbish off E Bay so after looking around have found theses which might for the job . Ordered a set and lets see if they work, they haven't got a stop built in but will be fitting a stop strap on the lid
https://www.absoluteindustrial.co.u...inless-steel-butt-hinge-316-marine-grade-p375
Hinges turned up today, 10 minutes to fit ( with a couple of 6mm washers as spacers and a check strap installed, fit is excellent and these hinges will never break
Great fix Neil and thrifty as well ����
Did you got for 38mm or 50mm?
need replacements after my box fell off today and bust the lid clean off!
