I am starting the process of replacing my fuel strip. Easy enough, remove pump assembly, remove old strip in its guide, put new strip in the guide and reassemble.
My first hurdle is access. The screws hoksing the fuel cap and its surround to the tank are well and truly rusted into their captive nuts. One cane out, I can see how badky rusted that one is. The captive nuts for the other 3 are just turning in the tank. That leaves the centre tank cover, and fuel filler neck, well and truly fixed to the tank. I cannot get to the top end of the fuel strip that way ☹
For probably the last 49 years my arms have been too large to reach the top of the fuel strip by through the fuel pump access hole ☹
Has anyone else had this issue and found a solution? I do not want to damage the body panels, and ideally not the filler cap nor the tank - at least not beyond repair.
I am only fixing this because I need to sell, I do not want to throw a lot of money, that I dont have, into new parts abd I don't want to pass issyes on to the next owner. Can these captive nuts be freed from the tank , i.e. spun until they heat up or do I have to bute the bullet and break the filler off then find a 2nd hand tank?
