OK, I have seen it done like this
2 people, 1 srewdriver, jump leads, insulating tape and a charged 12v battery. Wrap insulating tape around the shaft of the screwdriver leaving the tip exposed as well as a short section just below the handle to connect the jump lead to. Practice poking the tip of the screwdriver onto the positive terminal of the battery until you are confident that you can do this without the tip touching anything else or slipping off.
Attach one jump lead to the shaft of the screwdriver just below the handle. One person touches the screwdriver tip to the bike's positive battery terminal and concentrates on not letting it slip or touch anything else. The other person can then connect the remaining jump lead to a good earth on the bike, press buttons, fiddle with coldstarts etc. Once the bike is running, carefully withdraw the screwdriver having first disconnected it from the donor battery.
Be ready to ride away so as to avoid leaving the bike running at standstill and the overheating that will ensue.
