2013- LC
Stator - ( Alternator) is internal it occupys the area where the clutch plate was on the Hehxheads ,
Its a weak point, and a fail here , will relieve you of over 1.3K to fix, its an engine out & split, then new stator ring, and rebuild & replace engine
Labour is 16hrs alone
Shocks -F&R if ESA ( Most will be) only warranted for 30K and a rear is 1.2K part only !
The later bikes are not immune
ECU's battery's , throttle body's, throttle grip, wiring, cam sensors, all can fail !
If you mate is brave enough to punt for one, he can take out the extended warranty ,
however there are some clauses depending on the pre exsisting state of the bike.
If its got an extened warranty that has not lapsed, he can take it over with the £0 excess option,
if its lapsed, then bike will need the latest service due, carried out by the main dealer, and each claim will be subject to a £50 excess
Personally id go for a 2011 /12 TC i did the LC for the cruise and factory lowered .. it was a brief and very expensive 3 years !
