Oops, had an off
ianran
Here and there
Hi, I had a slow crash on my CRF1100, as a result it won’t go past 3rd gear.
There is a reset to the DCT, is that likely to solve the problem?
I had an issue with the dct in my 1000. Centre stand, ignition on, spin the rear wheel. Sorted my issue but if you can select 1/2/3 it does sound like you may have a bigger problem
Can you re initialise the dct gearbox on those like you can on the Goldwings? If so, try that, it seems to do the trick.:thumb
Thats my first point of call when I can move a bit freer. There is very little damage, the crash bar took the brunt with my leg luckily braking the fall :D
Cheers, had an unrelated finger op last Saturday. Currently, I’m down to only one working leg out of my limbs:blast
Brief update, all faults were caused by a dented ABS front ring!
Now working fine, a reminder that kiss is the best policy, Keep it simple stupid!!
