flytoolow
Hi All.
Does anyone have a "cock-sure" procedure to get a set of 32mm Bings operational?
Ive cleaned the carbs and the bike ran about 3 weeks ago with clean fuel - although not synched it did run and roughly idle
Now it fires for about 5 seconds with copious amounts of ether (AKA "Start ya B*st*rd") and full choke. Then it fires to about 4K rpm but promptly dies
When I used to play with 2 stroke model engines there was a procedure that said to blow into the carb, with a new fuel hose attached, and close the needle until you couldn't blow anymore, then open up the needle 2 full turns...always worked..
Does anyone have anything similar for a set of Bing 32's at all ? I just need to get the bike running, get it on a trailer and get it moved into a garage in france...anyone ???
F2L
F2L
