Morpheus
Hi, Quick question for all the garage dwellers, spanner wielders and the collective hive mind: -
I cant find the specifics any where in the Haynes manual, or online here or else where.
When removing the 1150 gcentre stand - after all bolts are out including belly pan and the bolts that hold the brackets to the frame, should the centre stand simply slide off (downwards away from the bike) or are the bushings stepped?
How does one remove the bushings, in order to drop both stand and bracket completely clear of the machine on both sides?
The bike is currently held up by 4 ratchet straps attached totes roof of the garage as my side stand bracket snapped so im removing the whole assembly for refurb and fitting a new GSA stand with bracket.
Currently having a cuppa and scratching head - any help (and pictures) would be greatly appreciated .. ta muchly.
Morph.
Morph.
