Possibly the wrong forum, but as its installed into my GSA, I thought I'd start here...
I have two autoswitches wired into the fusebox (using new relays). An AS4NB and the AS5NB2. The 4NB (one long press of the indicator to activate) works fine. As far as I can see, the 5NB2 (two quick presses to activate) is connected to the same places, but when activated, the 5NB2 turns on, then immediately turns off. According to the autoswitch website, "if your lights go off and you have to use the autoswitch to turn them back on then power to the autoswitch red (ignition switch connector) or black (ground) wire is intermittent".
As the 4NB is working fine, and the 5NB2 is connected to the same wires, is this likely to be a fault with the switch, or is there something else I can/should try? The website does recommend a bench test before installing, but this was never done and I don't fancy removing it all if I don't have to!
