You should start a rant, preferably in the Rant section.
Too late, bought it now..
Not really thought of it as a rant, just disappointed with above posts..
NavV map updated successfully first time using Garmin Express, but in a roundabout way....
In hindsight a better advanced solution may have been to use Garmin Express to save to both computer plus Nav V because it'll probably automatically delete the old map for you.
I'm confused & a little concerned.
I've not connected my Nav V to the laptop for some months.
Am I right in thinking, based on the above, that when I do I'll be offered an updated map which won't then fit on the unit?
Applying foresight, I think you are probably right.
Not that I have ever done it, but can't you put the micro SD card into a reader, plugged into your computer and use that to create the music files etc? I guess that would be quicker and easier. The Nav V should pick them up when you insert the card into the device.
That's exactly what SHOULD happen, but in the mysterious world of Garmin, it often doesn't with the result that people report not having enough space cos it doesn't delete the old map. Do it manually and reinstall and you'll be OK. Its Gmapprom.img that you need to delete before installing the new map and that'll sort any space issues, but ONLY DO IT if you are having problems, i.e. should NOT be necessary in the real world. (If worried back it up first)I used Garmin Express last week for the latest updates & it deleted the old maps, then installed the new ones all in the internal memory of the unit, sorted.
