I would recommend if you have bought Denali Lights that you consider applying grease to the lens screws before you fit them to the bike
my D3's are not a year old and the area around one of the 3mm screws has corroded so much so the head of the screw has sheared off
these lights are supplied with lens options and are impossible to change if you can't get the screws out
