Typical bloody Brit abroad!Wapping said:Voice Language: British English
Ya couldn't even switch the language to French!!
Greg
Just another datapoint...PanEuropean said:The software engineers are following this thread with considerable interest, and started looking into the matter yesterday.
st13phil said:BTW, any idea how I can run a route simulation other than in real time?
Phil
HMR said:When I started using a navigator 4 years ago (SP3) I quickly learned that both the woice prompts and the pop-up instructions where very often erroneous.
Most common error was that that the written or spoken text was "turn left" while the picture or map clearly showed a "turn right" situation.
After a while a found that 90% of the errors came where I had put a route waypoint exactly in a crossing/junction. Both examples in this thread fits into this category!
Rule 1: Never put a route waypoint in a junction/fork/crossing. Always put it on the road between the junctions.
Enough errors remains for me to have voice guiding & pop-ups switched off always. Today I use only the simplified "overlay" map screen guiding on my 276C. It shows me only the map plus time & distance to next change of direction. Almost no bugs nor confusion.
Maybe I should have written 70/30 instead of 90/10.Wapping said:I guess that these 'other errors' fit within the 10% leeway that your 90% prediction suggested?
Anywhere except exactly in the junction.Wapping said:Do you have a suggestion as to how far from the junction to put the waypoint?
I agree. But it's not a nation thing. It's more an issue of me always riding on small countryside roads. Very seldom in big cities or motorways.Wapping said:Not having the voice instruction / warning on may work well in the wide expanses of Sweden, where by-and-large, junctions on roads are reasonably clear for miles ahead.
HMR said:Maybe I should have written 70/30 instead of 90/10. Anywhere except exactly in the junction.
This problem doesn't seem to be related to map version. I have used V4, V6 & V8 and the only difference is that the problems shows in different places. Frequency is the same as far as I can see.
HMR said:...Most common error was that that the written or spoken text was "turn left" while the picture or map clearly showed a "turn right" situation. After a while a found that 90% of the errors came where I had put a route waypoint exactly in a crossing/junction. ...
PanEuropean said:Hi Richard:
Some follow-up questions from the engineering team:
1) Did you create the route or routes that took you through the three problem areas using MapSource, and then download these routes to the GPSRs, or did you create the routes directly on the GPSR?
2) Are any of the three problem areas that you mentioned close enough to you (or to another interested forum member) to allow you to create a route using the GPSR only, and run through the problem area again to see if the guidance mistake repeats when the route is created on the GPSR?
Lastly, the engineering team members compliment you on the thoroughness of your documentation of the problem.
Michael
