So far my experience of ghosting has been with the unit on the bike, with the engine running (Duh). I have never experienced it when using the unit in the car on 12V power.
So I realised that the difference between the two scenarios is that in the car, the cable just supplies power whereas on the bike, there is the Canbus data too.
If I get ghosting, I normally thoroughly clean the screen and the mount / device contacts but it doesn’t last long before the ghosting comes back.
I have long thought that the problem might be down to RFI on the data segment of the cable and then I remembered that I had some clip on Ferrite cores in my garage drawers. I dug one out and I fitted it to the GPS cable. It’s a bit loose but that’s not really an issue.
Subsequently, I haven’t experienced ghosting but it’s early days yet as I also cleaned the screen and contacts again.
I’ll keep you posted.
If you want to try this too, Ferrite cores things can be found on Amazon for not many pennies.
