Early adoption….why on why do I get sucked in ?
6 journeys 250-300miles journey and its failed unfortunately.
40mile ride in rain this morning (don’t know if that’s a factor - half the other mileage was in pouring rain as well) - jumped on bike this evening and it fired up ok. Had to make sure my iPhone was on Personal Hotspot screen and then it connected to the Nav ok.
Went to Navigator option - it showed a generic map pic, not where I was and just random roads without any names - looking like a standard image, then after a few seconds went back to main menu again.
Tried it multiple times, took it out the cradle, restarted Navigator - same thing.
Set off home (40miles) - pissing rain again. Got home, brought inside, reset again (on and off + keeping power button switch until it cycled). Same results for Navigation behaviour above.
So I thought I’d check settings. Same is happening to Settings menu option, when I choose that - just cycles back to main screen.
So I was going to factory reset from settings menu…..but I can’t get to that option now….so I’m stuck.
Other menu options work fine, routes show the route I took home !
I suspect software. If it was hardware (screen) then this would happen for every menu option. I have a suspicion it’s deleted the map from memory and perhaps something to do with settings….now it can’t open them because they’re not there. I’ll plug in tomorrow to computer and see if there’s a map folder etc.
It’ll be going back to the dealer for replacement next week.
I’ll let you know what happens
