Hi
Sorry to start my membership with a request for advice.
I've got a R100gs.
I was having front brake issues in that the front caliper wasn't releasing properly.
So far I have replaced the caliper seals and O ring, fitted a stainless brake line. Replaced the master cylinder piston etc. I've cleaned out the master cylinder and the fluid return hole which was blocked.
My problem now is that I can't get any pressure at the lever. I have primed and bled the system every which way. There are no leaks. I burped the master cylinder and there seems pressure there with my thumb blocking the outlet.The pads are moving but just no pressure and the lever is coming back to the bar. I'm sure there is no air in the system.
Any ideas
I've got a R100gs.
Any ideas
