So I bought some Venhill braided brake lines for my 96 R850R and they are race lines ie two lines from below the master cylinder one to each front brake. The standard brakes have a single line from the master cylinder to a splitter on the bottom fork brace/mudguard mount. So the question is with the race line setup how do I tether the lines to the forks? Non of the original fit stuff is a loop that I can pass the lines through. Does anyone make after market brackets? If any of you have fitted Venhill or similar what was you solution?
