Rear Brake Master Cylinder Seals
Pale Rider
Loughborough
Hi Guys. Ok found fluid weeping from the dust seal on the bottom of the rear brake master cylinder, I’ve looked on Motorworks for a seal kit but can’t locate anything. Does this mean the rear Brembo cylinder is non-rebuildable? or are seals available elsewhere??
Thanks again.
I had the same problem and couldn't source a seal kit or a new master cylinder anywhere. I bought a used one from Sherlocks, been fine ever since.
