- Joined
- Jul 14, 2010
- Messages
- 8,676
- Reaction score
- 467
Following on from the eBay R100 post ,I think this subject needs its own thread.
Obviously this is just my own opinion on the matter,but it is borne out from many restorations.
I have a huge issue with the type of recommissioning that consists of,a new battery,fresh fuel,and attempting to start the engine.
I’ll try and explain why.
Firstly
,the oil in the sump will over the years have settled out all of the dirt/carbon etc .
This will be sat in a thick solidified layer in the bottom of the sump,just waiting to be pulled into the oil strainer and oil pump.
Secondly,
Even in a nice dry garage the engine will suffer from condensation internally.
Air has a high moisture content.
The camshaft /cam followers can rust over time as the oil drains away and they dry out.
The same on the valve gear.
The piston rings can start to rust,as can the bores on pre nicasil engines.
The carbon on the piston crowns and combustion chambers eventually flakes off and sits around the rings which also holds moisture.
So as mateyboy cheers when the engine bursts into life on the eBay barn find that’s been sat in a shed for 20 years.
All of that carbon,rust and any other crap that’s found it’s way in will be washed into the sump,
Now although the oil pick up does have a strainer ,the oil filter is drawing up unfiltered oil which will wreck the oil pump and possibly damage the crankcase housing.
I never try to start or crank a motor that’s been sat for a long period.
I remove ,valve covers,cylinder heads and barrels.
I’ll also pop a conrod off .
Then I’ll drain the oil and remove the sump.
What happens next will depend on the findings,but I will know the state of the engine and won’t have caused any damage.
It’s not difficult or overly expensive to do the above.
Firstly
Secondly,
