I used toothbrush and SolvolI cleaned my wheels with an electric toothbrush and toothpaste..
I think this will be my solution although I dont really want to do the whole harnessWhen I sorted my early 1999 red 1150 last year what started as a small amount of the wiring loom wrapping breaking up ended up with me stripping all of the loom from front to rear and using a couple of rolls of self amalgamating electrical tape to re bind the entire thing
Why did you chose that over loom tape? Loom tape is a lot easier to work with and does a very nice job of doing what it's designed for.When I sorted my early 1999 red 1150 last year what started as a small amount of the wiring loom wrapping breaking up ended up with me stripping all of the loom from front to rear and using a couple of rolls of self amalgamating electrical tape to re bind the entire thing
Taking it off isn’t too bad, but it needs a modified socket to refit it. I’ve got a modified one I can lend if it’s any help. The most difficult part is removing the big nut that holds the pivot in the bridge, so I’d avoid touching that and just work around it in situ. Wire brush, sand and paint with Hammerite smooth silver.That bottom fork brace is bothering me too as it looks a tricky and quite expensive bit to replace and equally tricky to take off to refurb - Anyone any tips on refurb in situ ?
Loom Tape !Why did you chose that over loom tape? Loom tape is a lot easier to work with and does a very nice job of doing what it's designed for.
Loom tape while waterproof, is not really designed for cable looms where there is a lot of flexing involved, it‘s bonding breaks down with flexing over time and as it’s exposed, it gets dirty easily, which is why the OEM use tubing so that the wires can move inside the tubing.Why did you chose that over loom tape? Loom tape is a lot easier to work with and does a very nice job of doing what it's designed for.
Having taken the tank off ( it will probably need a pro paint job as there are some bad scratches that upset my OCD )
Wow thats a great offer butI have the exact same tank which I removed from my bike nearly 20 years ago. I'll have a look to see if it has any scratches or not but you're welcome to it for less than the cost of a respray and decals.
