mark2jag
Just a quick question to anyone in the know. If my S10 has a seat so low i can sit on it almost but not quite flat footed,(I am 5ft 9 tall) am I looking at a bike that has been built as a low seat version by virtue of a slightly different frame or is the seat height dependent on the plastic tray with the 4 rubbers on it under the seat. I'm asking because I'm told i have the low seat version, but when i went to get the bike it STILL had the plastic removable tray with the 4 rubber bungs on it, and removing them to make the seat even lower didn't seem to make much difference,
If you remove the plastic tray with the rubber bungs on it, is any of the vibration from the engine transferred to the seat, as mine felt a little vibey with the plastic tray removed or is it the same regardless ?
No question you don't know the answer to is a silly question apparently!!
Mark(2jag)
Mark(2jag)
