Well let’s put it this way I wanted to record my mates and I as we ride along on a video
Ok to start you can get a professional set up that gives you pax 100 mtr range (not a good set up on a motorcycle imo)
So what’s the solution
For me it’s a moya av200 ( cables are way to long 6 mtr from the power control box and 3 mtr each for both mice )
A packtalk bold
So to start if you fancy doing the same as me and pretending you a video editor
You will have to shorten the lines down to pax 12-14 inches not a big job ( well yes it is the wires are .25 mm you cannot solder them so you will have to get the smallest through crimps in existence)
And some small 3mm and 6mm heat shrink
Well after quite a feu days of straining my eyesight I did it and connected both my packtalk and the ghost cam together to test
Bingo it works
Let’s hope that my trip to Spain goes ahead to fully test my handy work
Oh and it all cost me less than £50 (apart from the cam and the packtalk
A packtalk bold
Bingo it works
