I have searched the forum for an answer to my query but can't find anything so I'm hoping someone who sees this can help.
Has anybody extended the wiring harness to the oem BMW nano fog/auxiliary lights by cutting the existing harness and soldering in new cables between the cut ends? I want to move the aux lights on my R1250GS from the BMW auxiliary light bracket under the nose to the engine bars. The existing harness is not long enough. If you tried extending the harness in this way, did it work ok? Did the mod throw up errors on the TFT? If errors did show on the TFT, can they be cleared with a Hex GS911?
My query is particularly about the harness for the current BMW "nano" aux lights, not the earlier model of lights. I want to continue using the standard switch in the mirror base. I don't want to make any other mods to the electrics, only to extend the length of the wiring to the aux lights. Nor do I want to drive the lights through an Ezcan or similar.
I've asked my dealer, but he doesn't know whether it can be done or not. I imagine I could use the GSA version of the harness, but I'd like to avoid the expense of doing that if I can.
Thanks in advance for any help offered.
