tank protector
grantmac
The Hague, Holland
Can anyone recommend a tank protector for a 2021 GSA. Seem to be a lot of options out there but I just want something simple to protect my tank (where it joins the seat) from my jacket zip which already seems to be making quite a mess of the paintwork. I have the tripple black.
thks
IF you are using a tank bag that has a magnetic base then you should discuss this with the dealer before any protection. I had a bad experience with it. Three months ago paint got damaged due to extensive use of this tank bag (https://www.vikingbags.com/viking-survival-series-motorcycle-tank-bag). Bag had the magnetic base, in fact, the tank was already coated with the protection layer but still got scratches there. So before coating, you need to make sure which tank protection type will be good for your tank.
Look at Helicopter tape, just make a pattern cut it out and clean the surface and look at Youtube. Quite easy to do not expensive just use a hairdryer to smooth out. Job done.
