Hi, looking at possible move to RS, is there a great difference in the 1250 and 1200? The TFT screen isn't a selling point for me, just wondered if it's worth the extra couple of thousand.
Thank for info, was looking at XR but can't find a factory low anywhere near me. The new one look pants.
Been discussed in plenty of threads, so you might want to do a search to get additional feedback. My own view is that the linear power delivery and additional torque of the 1250 makes for a more enjoyable and rewarding experience, giving more flexibility in the gears on country roads as well as an absence of the flat spots on the 1200. It's not so much about power peers see, but a much more flexible engine. So it really comes down to the extra cost of whatever 1250 you might look at .
Couple of points - the outgoing 1200 had tft - mostly 67 plates. Also, the ESA II (which has the auto settings to which wessie refers) came out on the 1200s, from around March 17. This will be easily identifiable, as that's when they updated the bodywork as well, and which didn't change on the 1250.
you seem to be talking about the GS - this is a query about the RS
Absolutely spot on Sir!No one can convince me that an extra 50cc, a colourful dash and a 5 figure sum will make my riding more enjoyable.
My 2015 Lupin Blue is still going as well as ever. Suitable cruising ability. Suitable overtaking ability. Top speed irrelevant in this age.
Go for the cleanest, best maintained, cheapest bike you can find.
The bike will always outperform the rider.
As mentioned above, the saving pays for the travelling.
Unless you want the newest plate at your local “biker cafe”.
ps - my GPS screen as I lounge on my Euro hotel bed. Bike parked up outside for tomorrow’s ride to ferry.
View attachment 264470View attachment 264471
correct but 3 different seat depths and swaps can be made relatively easy - when buying new, I think it is a no cost option to choose which one of the 3 you want, hence some buyers of a used bike want to change from the att seat to a standard seat etc.AFAIK no seat adjustment on the RS, one size fits only certain people
Then there's two Motorrad bar options, after market bar risers and aftermarket bars. There's even peg lowering kits so it's not hard to get one to fit well. For touring, the sports seat is the flattest and most cushioned but also the tallest. It does increase distance to pegs which is good, but you then have more of a stretch down to the bars which for many will mean bar risers as the best option. If swapping bars, I think the clutch would need bleeding, but unsure why this might be the case for just adding bar risers.
in my case, no. I think if I had used the version that brought the bars closer as well then I might have need to fiddle with the clutch line's routing. It's pot luck on which side of the cable tie the factory ape leaves the slack!Great info, thanks Wessie. Did you have to re-route anything?
