I was struggling to drag a route displayed on an iPad, so that it overlayed a track and the two matched. I asked the very helpful MyRoUte forum for a solution. It might be helpful to users here to see the answer.
My question to the MyRoute forum was:
The best answer was:
I then tapped and held the new point, which allowed me to drag the route to overlap the track.
I then very simply checked that the dragged point was correctly positioned.
Job done, with good help from the MyRoute forum.
I am struggling to find a way to reorganise shaping points into a logical order on an iPad.
For example, let’s say I have a long route of 300 miles, with 60 shaping points, one every five miles. If I then overlay a track of the route, I can see that the route doesn’t match the track in some places. I would like the route to match the track, so I have to amend it. That is fine but….
I can’t, as far as I can tell, drag the route on my iPad, as it simply drags the map.
If I insert a shaping, to force the route to follow the track, the shaping point is put at the end of the waypoint list. The only way I can find to move ithe new shaping point using my iPad, is to manually drag the last point up the list, into its correct place.
Am I doing something wrong or is this the only way to do it on an iPad?
Zoom into where you want the new route point (RP) and double tap the screen. This adds a new RP in the correct order.
