Clutch started slipping last year shortly after I got it so decided to do something about it a few months ago . Bike is 2000 1150GS with 175,000 but hadn't been used for aprox 6/7 years before I got it.
Starter out and bell housing very wet on the gear box side so I reckoned it was the gearbox input seal. Replaced the seal and rebuilt it but 100 miles later same again ! Took the box out again today
but lots of gear oil came out when I removed the clutch slave cylinder and on close inspection the new gear box oil seal actually looks quite dry.
Could the oil be getting past the slave cylinder then running down the clutch push rod making the clutch slip ?
Any ideas out there ( it definately isn't brake fluid)
