Great views guys, I agree, they appear to not give a f*** about this segment, but they must spend a significant amount on R&D to produce the XT / XT2 and then ruin it with stupid bugs that should be easy to fix, which makes little sense....
....Other than they probably had an R&D budget and timescale to get it on the market, employed a bunch of contractors to do a lot of the work and then despite the dev team saying "its not ready yet" they went ahead and launched it, sacked off all the people with the skills and knowledge to fix it etc. - Typicla big firm mentality / stupidity (I have worked in at least a dozen global firms with 100k+ Staff and they all do this kind of stuff, spend £5 million on something thats at best 50% correct, when £5.1 million would of had it at 90%+)
The point on loyal customer base is a good one, they are now pissing off the die hards that want a proper nav device, MRA navigation outperforms my XT in every way on the core function of either getting from A-B (put in location and hit go) or following a complex route.
Obviously no update from Garmin now, I think as well as my report they must have hundreds of people picking up on the flaw with GPX 2.0 (if not thousands) so I expect they won't fix it, although they kind of promote it as a feature - and one I really wanted to use.
The crazy part is this should be an easy fix, they have a route engine that works, but cocks up in this scenario, the fact changing back and forth on route options gets a correct calculation shows they can corrrecty calculate, the fact the missed shape points work prior to this recalc proves they have code that handles this properly too - so its a case of using the correct subroutines they alreayd have when importing and navigating a GPX 2.0 with Via and Shape points.
If they do not fix this I will 100% never buy another Garmin, nor will "we fixed it on the XT3" be acceptable as they will have proven anything not working on the XT3 will undoubtedly require purchasing an XT-4, and so it goes on.
If anything I will buy a ruggedized Android device and run MRA on that next time around, and for now just use gpx 1.1 - assuming they work OK, need to do some more complex routes in spring, but local testing implies they work with laods of wayppoints OK.
