EB02GS
I suspect because BMW would rather just sell you a new bike, or profit from the "big labor" associated with doing a complete, out-of-frame tear-down and rebuild necessitated by installing a one piece continuous cam chain. So we are clear, peening (aka staking....same thing) a small chain like this in situ isn't easy, nor totally trustworthy (per several industry experts). It's very easy not to do quite enough and have it later fail, or over-do it and create a stiff link that will cause the sprockets and cam rails to wear prematurely. I would much prefer a clip-type master link for a job like this, but again, I was unable to find one the right size. If not for my portable MIG (to tack the pin-ends afterwards for good measure), I wouldn't trust this job at all.I replaced the worn camchain on my old Yamaha Thundercat YZF600R years ago and the new camchain was supplied split and provided with a peenable pin in the kit from Yamaha. Replacement was the same method as you used to link old and new chains and draw the new chain through the crank. The old chain could be bent in a full semicircle sideways it was so badly worn.
I'm surprised BMW don't supply new split camchains with peenable links as standard ?
