Little Things
Redboots
Member well-known
Deux-Sèvres
Please little minds:)
You cant actually have a "Splash Screen" in the Montana, but you can change the wallpaper
For best results your picture needs to be resized.
For 4.3" wide screens (Montana) the picture needs to be resized to 480 pixels wide by 320 pixels high.
Better results from a less "busy" picture
It also needs to be in .jpg format.
If when you resize your picture and it looks squeezed, try cropping it to a "wide" screen look.
1) Connect the GPS to your PC.
2) Open the Garmin drive (unit) on your PC and then open the folder JPEG.
If you do not see this folder on your Garmin drive, create it. It must be JPEG in all capital letters.
3) Drag and drop (copy) your picture into this folder.
4) Go to the phot viewer menu.
5) Find your picture you added and tap on it.
6) Tap the menue button. (3 horizontal bars)
7) There is a box for "Set as Wallpaper". tap it.
8) The picture will display.
9) click back as many times as you need to.
Picture now displayed as your wallpaper
To undo it> Setup >Appearance >Background > and select what you want.
