So the saga carries on.
Ill start at the beginning. Got the bike in feb this year. An 05 1150 gsa 39k miles. It had sat for 6 years untouched. I did new battery, new fluids, spark plugs etc and it started and ran lovely. The first thing to die was the hall sensor. New one, seemed fine. Then it began very difficul/impossible to start, so i gave it to a mechanic. after 15 weeks(!!!)at the bmw specialist i got it back because they couldn't sort it. After some advice i replaced all the fuel hoses inside the tank because after inspection they had completely corroded and cracked. And hey presto.... Started!!! I then replaced the injectors and coils.
Then the abs failed. So I bypassed the abs system. All seemed good. I have just ridden it for 2 days. About 200 miles. Today it died mid ride. The engine just stopped dead. Left me stranded again. Electrics all fine. Turns over but wont fire. Batterys fine. Pulled the spark plugs and they're sparking fine but totally dry even after many attempts to start it. Fuel is coming from the lines, fuel pumps working but the injectors are just dribbling fuel when i turn it over. These are brand new injectors. All parts from motorworks.
Im booked on the channel tunnel to ride to germany this week because my partner there has been hospitalised. Im utterly at the end of my tether with it but after spending sp many many hours and a fair bit of money on it im determined to sort it, and it seems lile it should be such an easy fix, but no one yet can do it. Any ideas would be very very welcome, thanks.
