Michaelwhy
Hi all
I am currently rebuilding what was a tatty 2003 1150 GS, it’s been fully stripped, repainted and I am busy reassembling. I am at the stage where the wiring harness is back in and this is where I have run into problems
I push the start button and nothing happens.
When the key is turned I get the dash lights and when the tank is fitted I hear the pump priming. All the lights, indicators work ok
A previous owner removed all the abs electrics seems to be a fairly pro job and the bike has ran like this before the strip down
I broke the gear sensor and lost one of the 3 pins so I am getting the green neutral light but the rid is saying gear 4 . New one on the way. But I didn’t think this was in the starting circuit so shouldn’t prevent it cranking
If I turn the engine stop switch I can hear a relay click and again when moved back to the on position
If I jump the starter motor from the large positive bolt to the small black spade on the solenoid the bike cranks just fine, it also is sparking and I can smell fuel so looks like coil and injection side is all ok, but have not tried with the tank connected or spark plugs fitted yet
So everything looks ok apart from something in the starting circuit, would the gear selector switch tell the ecu not to start or what else is in that circuit that the ecu checks before sending the signal to the starter, side stand switch seems ok as does the clutch switch. I was under the impression if the clutch was in then it would start either in gear or with the side stand down so even if these were faulty it wouldn’t prevent it from cranking off the button
Any thoughts on where to look or what sensors would prevent the button from sending the start signal
Mike
Mike
