Must just be you then
Helps, if you're suave, debonair and cute.
Like me
Sent from my SM-G925F using Tapatalk
Like me
Like me
my bike is a lot better on the bottom end.. used to have a flat spot 4-5K.. that has now gone, but a bit flat 5-6K then its off again...
anyone else see this?
A proper re-map will get rid of the flat-spot.
Exactly, hence the word 'proper'.
I will be taking mine (1250) to be tickled , as I know it will need it .
When are you going? I’ll be taking mine there, so keen to see your results.
What NO charge, not even Jaffa Cakes ???Let me save you the anticipation...
Pre remap: 108bhp @ 7750rpm
87ft/lb @ 6250rpm
Post remap: 128bhp @ 7750rpm
102ft/lb @ 6250rpm
No charge
87ft/lb @ 6250rpm
102ft/lb @ 6250rpm
No charge
87ft/lb @ 6250rpm
102ft/lb @ 6250rpm
No charge
Standard can or Akra?
Boxertissues will be seething when he sees the pre figures!
When did you get that done
I haven't, it was a prediction...
