Need some advice here guys.
Knowing the bike started and ran before this problem is the starting point.
The bike: 1989 R80RT Mono outfit.
It all went wrong when I started the bike after fitting leading link forks as detailed in my other thread.
There has been a power surge of some sort, which has taken out something, I'm not sure what??????
I pressed the starter and it fired up straight away.... But the starter motor didn't disengauge for a second or two (literaly 1 or 2 seconds). Then the neutral light went out and it stopped. Hmm?! switched off and on, lights came on pressed the button, it fired up, then lights out and stopped. Did this a few more times with no joy.
The next morning I turned on the ignition. The dash lights came on dimm, then brightened and I could hear a realy quiet fizzing noise coming from somewhere up front. Then the dash lights went out. I did not try to start the bike.
What could this be?
Battery is good with good charge.
So far, I have removed, stripped and cleaned the starter. It was quite gummed up in the bendix. Bench tested and refitted and tested again. All good.
Then I started checking the electrical connections and relays. In the process of checking connections, I inadvertently put the lighting relay in the starter relay's slot. That did it. Lots of smoke, a lovely red glow and a burnt out earth wire down to the neutral light switch. Oops.
I've now traced and replaced the wiring and fitted new starter and lighting relays.
Now when I turn on the ignition, I get, parking lights on first click, correct. Then on second click, I can turn on and opperate all the lights, brake lights and indicators. But no dash lights, no ignition, starter button does nothing.
I've pulled the starter and kill switches apart, checked, cleaned and reassembled and tested that they work at the relay.
Prime suspects:
I'm thinking one or more of these is the culpret, but have no idea how to test them.
Regulator,
Diode board,
Hall sensor,
Ignition amplifier.
Any ideas?
Val.
What could this be?
Prime suspects:
Regulator,
Diode board,
Hall sensor,
Ignition amplifier.
Any ideas?
Val.
