I've been fixing up a R65LS. I've just put a battery back on to test the electrics and the ignition is permanently on. The rev counter instrument lights are illuminated and the starter motor can be activated. Apart from not switching off, the switch performs as it should; parking light, light off, pilot on, then headlight on. I've tried a different starter relay and checked the wiring diagram. I had not removed the wiring to the ignition switch. It would appear that I'm missing a yellow/white wire that should connect to the ignition switch
There's also some strangeness with the light relay. A copper wire links 2 terminals. Without this, the headlight doesn't come on. I've tried another relay there too and it also didn't work without the wire bridging connection.
As far as I recall, you could switch it off when I got it, but it was in such a state that I didn't use it and took it apart straight away. It was registered in Germany and later imported to the UK, though I'm not sure if this means it is different from a UK model. It's also got a Boyer Bransden ignition. Is there anything obvious I might check? I did take photos and was careful about putting connectors back where they came from.
Sent from my SM-S901B using Tapatalk
