Ok. This is a story I need to first layout the history. Then see what you think of my ideas...
A year and half ago I had a pair of CTA 3s fitted by ProTyre here in North London. I'll be coming back to this detail later.
About a week later I jumped onto the steed for it's regular outing down to Italy. Immediately on the M20 down to Eurotunnel I was aware (hard to miss!!!) vibration from the front at around the 130kmh mark - it faded away at 140+kmh, but crept back in, less pronounced, after around 155kmh.
So I did a return trip with this flippin vibration.
On returning to London I took the wheel to a bike shop near me. They added 10g at about the 9 o'clock position - a first for a weight to be added not opposite the valve... It mostly worked, but not completely.
Fast forward to this last week. I decided, while in Italy to replace the front tyre. Get rid of what I decided was a duff tyre from the start. CRA fitted this time.
Onto the auto strada to discover the vibration is back, much like it was originally . FFS.
The vibration is not continuous, it fades in and out at roughly 1.5Hz. it's not massive, but can clearly feel it in the bars and I can see the mirrors and dash vibrating on and off as it gently pulsates.
My thoughts:
Wheel bearings knackered? (They feel smooth)
Spokes loose? (Need to check them)
It's definitely associated with the front wheel as this change of tyre demonstrated.
Additionally, this story only appeared straight after that tyre change a year and a half ago.
The last point referd to Protyre who fitted the CTAs. In the days after fitting, I found two bent spokes on the rear wheel - I replaced them.
But did something else happen to the front wheel? But what could have?
I called ProTyre to complain about the bent spokes and was told that around the same time he did my tyres, there was a bust up, the fitter left the business and took all his tools (or walked off with tools belonging to the business!).
I'm really not sure what else would cause the vibration, that is clearly associated with the front wheel. Wondered about the gearbox and if a tooth was missing, but there is zero vibration in my feet or backside, which I would expect if that was responsible?
Any wild thoughts out there?
Bit of a story. Apologies!
Sent from my SM-S908B using Tapatalk
My thoughts:
