bosnjo
This issue has been largely discussed on this and on US forum.
It's all about the battery problems from the factory or the replacements that are not strong enough.
The problem occurs when cams stop on the highest compression position when you turn the engine off. In that case, the starting procedure needs a lot of CCA power from the battery. That is the reason it sometimes happens, sometimes it doesn't. It all depends on the cams position.
So, after a lot of posts, the conclusion is, the best battery cost wise:
Yuasa YTX14H-BS - 240 CCA
Dimensions: 150mm x 87mm x 145mm
1.2A, CCA 240A, 12Ah
